reaper- Posted August 7, 2008 Posted August 7, 2008 Hello. Installed the latest DVBViewer pro version (non beta) and the latest webstreaming version (1.5). Before that I used version 1.2 and ASF-streaming which worked fine. I can connect to the webinterface but when I try to stream nothing happens. I have VLC installed but it doesn't start when I try to stream, am I missing a setting or something? Also when connecting to the stream from VLC or WMP what settings should I use? I also whonder about the settings when trying to stream. What is the difference from embedded and not, that the player is embedded in IE? Also not sure which muxer to use, what difference will it make to change the muxer? Should I transcode video and audio or not and which format is the best? Thanks for your help. /Daniel Quote
