ilaps Posted August 8, 2008 Posted August 8, 2008 I am using DVBViewer pro since several years, with delight since it worked perfectly, even with HD from ASTRA-HD demo channel and ANIXE. I use PowerDVDultra 7.3 codecs and HD2400pro, full hd, with a very low CPU load <10%. But since end of july, no more image. If I remove DXVA, then I have image again, but with 80% CPU load and some stuttering. Nevertheless, I can record programs, and watch it with powerdvd, using dxva. Here also, some stuttering. I have tried to use VMR7/9 instead of overlay: nada! Using the tool H264 param reader 1.3 I have seen that old programs were using H264 main profile whereas now they are using H264 high profile. I mention that I read perfectly BRdisks in H264, like "casino royale", which I believe use high profile. Is this the reason of my problem? Has someone experience about this problem and solutions? Thanks for your help Quote
Tjod Posted August 8, 2008 Posted August 8, 2008 Is this the reason of my problem?Some TV Station charged there encoder and use now a higher h.264 Profile.http://en.wikipedia.org/wiki/H.264#Profiles And some decoders for example Power DVD 7 have problems with the new Profile. Quote
