uksatcom Posted August 9, 2008 Posted August 9, 2008 Morning all Apologies for this as I am sure this topic must have been covered in the past , but a forum search of Mpeg 422 shows nowt ! I am trying to fire up 422 in DVBViewer pro For some reason the settings section doesnt give access to the Elecard facility ( already loaded ) but I seem to recall seeing something about DVBViewer not being compatible with Elecard and the need to use something else To save going over old ground , can anyone point me in the direction of an existing thread which covers this....and if need be , the alternative to Elecard. Device is TT S2 3600 USB Many thanks Quote
Griga Posted August 9, 2008 Posted August 9, 2008 but I seem to recall seeing something about DVBViewer not being compatible with Elecard No problem here. ffdshow as MPEG2 decoder supports 4:2:2. Set Start Menu -> ffdshow -> Videodecoder Configuration -> Codecs -> MPEG2 to libmpeg2. Quote
uksatcom Posted August 9, 2008 Author Posted August 9, 2008 Excellent ....many thanks for such a prompt reply Quote
bob0r Posted October 19, 2008 Posted October 19, 2008 No problem here. ffdshow as MPEG2 decoder supports 4:2:2. Set Start Menu -> ffdshow -> Videodecoder Configuration -> Codecs -> MPEG2 to libmpeg2. http://x264.nl/422/10-19_13-51-02_2-SAT_H161_(fre)_.ts Latest ffdshow tryouts fails here. Also Elecard does not give video in DVBViewer, it does in MPC. Quote
CiNcH Posted October 19, 2008 Posted October 19, 2008 (edited) it does in MPC So try the MPC Mpeg2DecFilter then... click Or try a different MPEG-2 lib within ffdshow (libmpeg2 <> libavcodec). MPC Mpeg2DecFilter uses libmpeg2. Edited October 19, 2008 by CiNcH Quote
