trifon33 Posted August 9, 2008 Posted August 9, 2008 Hi all. There are different sources for TP ini. One of the most popular real time updated come from KingOfSat. I have found different syntaxe from the one in use in DVBViewer; especialy for DVB S2.. Is it compatible or is it necessay to update manualy lines for correct DVBViewer working??? Thanks Quote
Griga Posted August 9, 2008 Posted August 9, 2008 TransEdit (-> members area) is able to read the KingOfSat syntax (with "S2" specifying DVB-S2 transponders). Perform the following steps for converting the list to the DVBViewer syntax: - Load the TP.ini with TransEdit, or let TransEdit load it automatically when launched by storing the list in the DVBViewer Configuration Folder\Transponders. - Change something, e.g. by adding a transponder description. - Click Save. However, the KingOfSat lists do not contain additional parameters that are required for some DVB-S2 devices (Hauppauge, FireDTV), particularly modulation and pilot symbols. They must be set manually in TransEdit. Quote
