feucar Posted August 10, 2008 Posted August 10, 2008 Hi all, I'm using DVBViewer Pro in a networking environment, in details: - 1 Server with free-to-air DVB-S (and I hope DVB-T soon) - 2 or 3 clients around the house I suggest to improve funcion in this area, for exemple: - Centralized recordind (for example and option so the client when set e timer can choose if the timer itself have to be executed locally or by server) - (today i'm using e copy of DVBViewer installed on server and i set up timer by remote desktop but this configuration is a bit tricky because you must assure that the server instance of DVBViewer have to startup/exit at start/end of timer as if remain running it prevent the possibility to change channel by other client. - Obviously some related function like client review and modify of the central list of timers, client browser and view of registrations (actually I send all registration in mpg format to a shared directory and browse it file by file), ecc. - Centralized grabbing and distribution of epg I stop here (its not a functional requirements document ;-)) but I hope that my idea is understandable. Thanks Quote
