94brg Posted August 10, 2008 Posted August 10, 2008 During installation of DVBViewer I got an error message saying "processor not supported" and now am getting a "no hardware available" error. The tuner appears under options/hardware as "Hauppauge WinTV 88x DVB-S/S2......." Attached is my support.zip, I am unable to find the DVBViewer.log or setup.ini files The PC spec is as follows, Medion 8835 PC AMD PhenomTM X4 9500 Quad-Core Processor 500 GB hard disk 3 GB RAM NVIDIA® GeForce® 9500 GT 256 MB graphics Hauppauge HVR-4000 Thanks for your help. Matt support.zip Quote
94brg Posted August 10, 2008 Author Posted August 10, 2008 Should have said, I searched on HVR-4000 and no hardware and see others have had similar problems, but couldn't find a fix anywhere. Quote
94brg Posted August 10, 2008 Author Posted August 10, 2008 Fixed now, it was a problem with Win TV and the driver. Quote
