burtz Posted August 10, 2008 Posted August 10, 2008 I cannot find DVBserver programme to enable Network streaming. Is this installed with DVBServer Pro 3.9.4? Or is it part of the options tab now. I am trying to follow the instructions in the manual but can't find the DVBserver programme box as in the screenshots? Quote
Tjod Posted August 11, 2008 Posted August 11, 2008 The DVBServer installation is a option in the setup. To install it go Start menu > Programmes > DVBViewer > Support > Modify DVBViewer Pro and select there "DVBViewer Network Server" and may be "Netstreamig Plugin" (a other streaming possibility). DVBServer is for streaming to DVBViewer Clients in the Clients you must configure the Unicast Device (Options > Hardware). Netstreamig Plugin is for streaming to other clients like VLC Player (in VLC select http streaming http://ip-addres:selected-port ). In this case you can use the DVBViewer Web Interface for channel changing. http://www.DVBViewer.info/forum/index.php?showtopic=27131 Quote
burtz Posted August 11, 2008 Author Posted August 11, 2008 OK Thanks for that. If I don't have "Modify DVBViewer Pro" in my start menu what do I run from the DVBViewer directory please? Quote
Lars_MQ Posted August 11, 2008 Posted August 11, 2008 windows control panel -> software -> DVBViewer Pro -> modify Quote
