headrat_uk Posted August 12, 2008 Posted August 12, 2008 (edited) Hi, When I setup DVBViewer for the first time (Vista X64 Ultimate) I get the following:- German error message? Also what are the differences in the version below? Description: DVBViewer ( 314790 Downloads ) » Version: V3.9.4.0 » Size: 6183 KBytes » Last Updated: 29.05.08 Information » Description: DVBViewer GE ( 4061 Downloads ) » Version: 2.5.0 » Size: 1394 KBytes » Last Updated: 06.06.08 Information » Description: DVBViewer GE Anleitung ( 2619 Downloads ) » Version: Deutsch » Size: 833 KBytes » Last Updated: 06.06.08 Cheers HEADRAT Edited August 12, 2008 by headrat_uk Quote
Tjod Posted August 12, 2008 Posted August 12, 2008 Pleas test if Channel Scan in DVBViewer work. And pleas post you support.zip if this did not work. Quote
headrat_uk Posted August 12, 2008 Author Posted August 12, 2008 I can't get past "Configuration Wizard" as it never finishes the setup Quote
Tjod Posted August 12, 2008 Posted August 12, 2008 Go on one step back in the Wizard from the scanning window and select no for scanning. Quote
headrat_uk Posted August 12, 2008 Author Posted August 12, 2008 (edited) When I hit the scan button it doesn't do anything! Edited August 12, 2008 by headrat_uk Quote
Tjod Posted August 12, 2008 Posted August 12, 2008 This is for Scanig for new Hardwar. Go to Channel > Channel scan. Quote
headrat_uk Posted August 12, 2008 Author Posted August 12, 2008 (edited) Doh! Nothing happens when I press "scan" here either. Edited August 12, 2008 by headrat_uk Quote
Tjod Posted August 12, 2008 Posted August 12, 2008 Start the DVBViewer via start menu > programmes > DVBViewer > support > DVBViewer Pro (Debug Mode). And than tay it with Scan Range. And than post your support.zip. And did the Hauppauge Software finds Channels in Vista X64? Quote
headrat_uk Posted August 12, 2008 Author Posted August 12, 2008 support.zip Still no joy scanning, yep it picks up fine in VMC. Quote
Tjod Posted August 13, 2008 Posted August 13, 2008 I have looked in to the support.zip but no idea what the reason is or how it could be solved. You can tay TransEdit from the members section for a channelscan. If it works you can send the channels to the DVBViewer. http://www.DVBViewer.com/griga/TransEdit%20E/Content.html Quote
headrat_uk Posted August 13, 2008 Author Posted August 13, 2008 (edited) Still no joy, seem like it doesn't see my DVB hardware? Edited August 13, 2008 by headrat_uk Quote
Tjod Posted September 10, 2008 Posted September 10, 2008 Do you have the "Windows Media Center TV Pack 2008" (Fiji) installed? Quote
Tjod Posted September 26, 2008 Posted September 26, 2008 Hopefully in the current BETA 3.9.4.70 the problem is fixed. Change: BDA direct tuning mode: In direct tuning mode an internal network provider is now used instead the MS NP. Hopefully this will help with the $FFFFFFF Error on some x64 Vista systems. http://www.DVBViewer.info/forum/index.php?...st&p=214283 Activate Options > Hardware > Direct tuning Quote
LeClerc Posted November 6, 2008 Posted November 6, 2008 Hopefully in the current BETA 3.9.4.70 the problem is fixed.http://www.DVBViewer.info/forum/index.php?...st&p=214283 Activate Options > Hardware > Direct tuning Hi Tjod, I'm having the same problem with my Vista x64 with TV Pack. I can scan satellite (and get HD) no problem but cannot scan Terrestrial without the error listed earlier in these posts. Looking in the members area for the beta 3.9.4.70, however can't find it?..... Regards LeClerc Quote
LeClerc Posted November 6, 2008 Posted November 6, 2008 Where is Version BETA 3.9.4.90 Ah!! I see. Thanks Tjod - I guess I'll just have to wait! Quote
