IDVBHardware - which tuner?
Valts
Hello,
started messing around with COM a bit, to get that damn signal level where I want it... so I managed to read signal data via IDVBHardware and even set property for the skins. The question however is that I am unsure which card is being used to display whatever is on the screen. I kind of expected to see card index in the property CurrentChannel: IChannelItem or in the Tuner:ITuner it contains but so far no luck. Please advise.
If you look into the Doc you can see, that the currentChannel property in DVBViewer class has the property Tuner wich should be current tuner you need..
I know it has Tuner property inside - I wrote about it. My question is which cardindex = current channel.
  • 4 weeks later...
I noticed that there should be IHardwareInfo interface present somewhere guid={7248686D-CBB1-44B8-AC14-A888399595B1}. Could someone advise how to get it?
