Version 3.9.4.0, HTPC mode help needed
DogZilla
I am a paid up member (Joined today) I purchased DVBViewer after extensive viewing of the DVBViewer manual, part of my decision was related to the HTPC mode mentioned in the manual.
After receiving the user id/password I immediately noticed that the manual is based on a previous version, this version does not give me an option to use HTPC mode :)
I tried downloading an OSD skin and placing the directory in the OSD folder and the scripts in the correct place. I was then able to select the XBOX skin and select and apply the change in settings.
There was no skin after this. I quit the program and loaded again but still all was the same. Under OSD, it shows that the XBOX is the selected OSD skin.
Please can someone point me in the right direction.
Thanks in advance
Press OSD-Menu [Esc]
Thanks for the prompt reply.
Escape does nothing once pressed so I am not sure what I am doing wrong.
Regards
Pleas Post you support.zip
How about that, my escape key has died :) All working now.
Will also use this as an opportunity to thank you guys for making a great application, best 15 euro I have ever spent.
