chrlau5 Posted August 17, 2008 Posted August 17, 2008 Hey I often get no picture only black screen when changing channels. Sometimes sound but most of the time no sound and no pic. It happens in about 1/10 channel changes does not matter if it is from SD-SD SD-HD or HD-SD. I can see other people have had the same problem. Is it a bug???? System DVB-C Cable provider Yousee Denmark Technotrend C-1501 latest drivers and Viacees Vista Ultimate latest drivers DVBViewer Radeon 2600 for HD acc. PowerDVD codec Kind Regards Christian Quote
chrlau5 Posted August 19, 2008 Author Posted August 19, 2008 Pls. HELP me :-) Kind Regards Christian Lauritzen Quote
trifon33 Posted August 19, 2008 Posted August 19, 2008 Hi, This is likely well known DVBV issue. You need to restart the graph in case of black sreen. Check different codec. Quote
chrlau5 Posted August 19, 2008 Author Posted August 19, 2008 Thx for answering, but is it something DVBViewer are working for a solution on? Anybody got an idea of what MPEG2 codec i should try? Are there anybodu without this issue? What codec are you using? Quote
