peneau Posted August 19, 2008 Posted August 19, 2008 Hi Everyone, I'm experiencing a sound problem on some of the U.K. (FTA) DVB-S channels. I'm using DVBViewer Pro 3.9.4 with a Hauppauge Tri Mode Tuner HVR-3000. The main channels (BBC, ITV, Ch4, etc) are fine both audio and visually, however, on BBC News for example I'm experiencing sound stuttering (video is fine) and signal strength is good, and also on some other channels such as movies4men. Also is there any sign of a bug fix for the "No Hardware Available" problem when switching from DVB-S broadcasts to DVB-T in this version of DVBViewer Pro. Any help or suggestions, greatly appreciated. Pentium4 3.02ghz, 2.5mb Ram, WinXP Pro (Service Packs installed) ATI Radeon x1950pro, Hauppauge HVR-3000 Quote
Tjod Posted August 19, 2008 Posted August 19, 2008 I'm experiencing a sound problem on some of the U.K. (FTA) DVB-S channels.Tay AC3Filter as audio decoder (Options > DirextX).http://ac3filter.net/project/1/releases Also is there any sign of a bug fix for the "No Hardware Available" problem when switching from DVB-S broadcasts to DVB-T in this version of DVBViewer Pro. This should work in the current Beta.New: Hybrid Tuner Support (HVR & Co) does work now. Please delete your hardware.xml in the userdata folder, so the DVBViewer does a new hardware scan. http://www.DVBViewer.info/forum/index.php?showtopic=27719 Quote
peneau Posted August 19, 2008 Author Posted August 19, 2008 Tay AC3Filter as audio decoder (Options > DirextX).http://ac3filter.net/project/1/releases This should work in the current Beta. http://www.DVBViewer.info/forum/index.php?showtopic=27719 I'll try that Tjod and thanks for taking the time to reply, much appreciated Quote
peneau Posted August 26, 2008 Author Posted August 26, 2008 Tay AC3Filter as audio decoder (Options > DirextX).http://ac3filter.net/project/1/releases This should work in the current Beta. http://www.DVBViewer.info/forum/index.php?showtopic=27719 Just a follow up Tjod, installed the latest AC3Filter as you suggested and sound issue is resolved. Regarding the no "hardware available" problem, being somewhat new to this, I wasn't brave enough to mess around with files and so I've not installed the DVBViewer beta version, I can live with closing the graph when switching between DVB-T and DVB-S broadcasts, until a new version of DVBViewer appears hopefully with the support for hybrid cards included. Thanks again Tjod. Quote
