Window mode turns channel to black screen.
jimmyg
system:
AMD dual core 4200
Vista 64 bit
Geforce 8500GT
DVBViewer Pro V3.9.4.0
Settings:
Cyberlink Mpeg2 Decoder
EVR renderer.
I use DVBViewer in conjuction with an HTPC. I have my remote mapped to a key which toggles the DVBViewer screen from window to full screen mode. So I can change channels from the HTPC.
This system works superbly well except that every so often the screen goes black when reduced to a window. Bringing up the full screen makes it reappear and the next time window mode is selected it may work OK. or not, it seems to be random.
This is a fairly minor irritation but a cure would be nice.
What is happening here !
Edited by jimmyg
  • 3 weeks later...
Got a same problem here.
Today I bought the DVB Pro version since I had problems with the Technisat version in combination with ATI 4870X2.
Everything is running smoothly except when auto aspect ratio does its job and tries to change from 19:6 to 4:3 of the other way around.
The screen turns to black immediately. Changing from full screen to windows mode resolves this minor bug.
Anyone familiar with this problem ?
All decoding is done by PowerDVD 8 Ultra.
I'm quite sure they are not DVBViewer problems, but meanwhile you can:
- try to update the video card driver's and DirectX (download and install free DirectX 9&10 update dated august 2008)
- try also with different "Video Renderer" (Settings/Options/DirectX)
Ah, and next time you want to pin out a supposed DVBViewer bug, please carefully read first the advice you found pinned ont top of the Bug Reports page:
Always follow these instructions. Otherwise no one can - or wants - to help you!
Are you using Vista?
If yes the "Black Screen" has nothing to do with DVBV. It` s a known issue of the EVR-Renderer (Buffer).
For the time being there is no real solution for the Problem except changing to another Rendere (VMR7/9 or Overlay) and thereby loosing Aero Glass or to live with it until M$ updates EVR.
Greetz
Pinbot
Greetz
Pinbot
Thanks Pinbot !
This is the problem indeed. I changed rendering from EVR to Overlay and the problem is gone.
So, now we will have to wait when Microsoft will cure its EVR bug.
  • 1 month later...
I can see that this post seemed to annoy you!
As it has 345 views to date, I am "quite sure" (your words) that it has helped a number of people with a similar problem.
This is what The DVBViewer bug report section is for.
Yes and I did indeed read "carefully" the pinned advice section.
The problem may or may not be Microsofts renderer.
I think the previous suggestion of it being The EVR renderer may be the solution.
Please do not be so quick at jumping on your high horse to complain about a perfectly sensible and valid bug report, which has helped people sort out their black screens !
Edited by jimmyg
