AHiemstra Posted August 20, 2008 Posted August 20, 2008 Hi, I have 2 DVB-S2 cards installed: KNCOne DVB-S2+ with CI Terratec Cinergy S2 PCI HD CI When I only have the KNCOne card installed, *.ts recordings run fine. When I have 2 cards installed, *.ts recordings are truncated either to 0 bytes or a couple of Kb. What is the cause of this behavior? Regards, Arjen. Quote
AHiemstra Posted August 23, 2008 Author Posted August 23, 2008 Is there anybody with 2 DVB-S or S2 PCI cards from 1 or 2 brands in 1 system who can normally view and record? I just tried again. Disabling the card in DVBViewer does not solve the issue. Even if I remove the card from DVBViewer, the recordings do not work. I looked at the resources that the cards use. They do not share interrupts. This is totally weird to me. What good is a DVBViewer program that only allows 1 card? Or is the trick to have 1 PCI card and 1 USB card? Quote
