CrashingDutchman Posted August 26, 2008 Posted August 26, 2008 Hi, I have assigned the number-keys (0-9) to go to my favorites, but something strange is happening. When I press '1', I expect my favorite '1' channel to show up, instead it shows favorite '2' channel. When I press '2', favorite '3' shows up, and so on... Are the favorite channels zero based? What should I do to have this corrected? Thank you very much in advance! Quote
Inxs Posted August 26, 2008 Posted August 26, 2008 Favorites start with 0, there is no way to change this. Quote
CrashingDutchman Posted August 26, 2008 Author Posted August 26, 2008 I hate zero based things! Starting with 0 for favorites is bad practice, in my opinion, if you open a box of chocolates, the first chocolate you take from it is not number 0 but number 1. Well, aybe there is a good reason for this though, I would love to hear. I solved it by putting a channel I won't watch too often on position 0 now... as a workaround. Quote
hdv Posted August 26, 2008 Posted August 26, 2008 Hello, from 0-9 you can select 10 channels with one click from 1-9 you can only use 9 channels Quote
galmok Posted August 26, 2008 Posted August 26, 2008 Hello, from 0-9 you can select 10 channels with one click from 1-9 you can only use 9 channels Well, I have no recollection of _any_ tv, vcr or similar equipment where the first channel is 0. Also, when you use the argumentation of 10 channels numbered from 0 to 9, you have to remember that 0 is placed far from channel 1 (physically on the remote) that is the next logical channel. Remotes look like this: 1 2 3 4 5 6 7 8 9 0 Not like this: 0 1 2 3 4 5 6 7 8 9 Quote
