Channeledit 1.5.1 bug discovered
Flepp
Hello
I am registered DVBViewer user since 2002 and it's quite a long time i haven't been in this forum, but i am very pleased to know that all my accounts work fine since that time. :blink:
I would like to report a bug in Channeledit.exe 1.5.1.
When in the same Root there is a category (provider) and a channel with exactly the same name, then there is some strange link between the Category and the Channel, even if Channel is in other Category.
I have attached a small channel.dat and test.dat as an example in the support.zip file.
- Load channel.dat in DVBViewer and Channeledit.
- Expand the tree in both apps and you will see the bug immediatly.
- Move all channels from source to destination in Channeledit and safe to test.dat
- Reload test.dat as source and see the results.
So in the hope that there will be a future release, i send you herewith my kind regards
Flepp
