DVB subtitles problem !
AjeeB
hi,
I just talk with Tuxbux community support for the same problem
DVBViewer also can't handle subtitle
you can see here but until now no answer
i did claimed before by mistake that DVBViewer support but it does not ! talking about lastest version
http://www.pli-images.org/forum/viewthread...;thread_id=6635
and here full TS sample
http://rapidshare.com/files/141383444/yes-subtitle.zip.html
I think it's new kind of dvb-subtitle !
if anybody can help i will upload TS via DVBViewer ;)
BR
Edited by AjeeB
I just tested the file you uploaded, it has 3 subtitle streams and all three work in DVBViewer 3.9.4.0 so it's something at your end.
Have you enabled subtitles? (Settings - Subtitle)
Edited by SimonP
yes I did ! ;)
but never works on-the-fly !!
and these channels have freeze !! with official card
BTW which codec you use? I try with cyberlink PDVD8 !!
BR
Edited by AjeeB
I tested also, works OK, there is also 2 audio streams russian and english. Which first language you have in dvbsub settings ? If I select russian as second (I have Finnish as first) they will show automatically.
yes it's works ! ;)
but there is mis-synchronization !! subs appear half second before !
any idea
thank's ppl
any idea
You can add 500 ms dealy in settings / DVB subtiitles, DVBV does not use transmitted timecode for subtitles so they appears usually too early.
By the way, that 500 ms is quite small, I use 2 sec myself, ofcouse it is also matter of brodcaster.
thanks very ppl ;)
keeep going
cheers
