newera Posted September 1, 2008 Posted September 1, 2008 Hi all, I have a small issue when I am using motor in DVBViewer. When I scan and use goto positioner motor moves to positions I give it for ex from Astra to Hotbid and vice versa. However when I change from a channel in Astra to Hotbird motor does not move. Channel editor shows that channels are using postioner. IN fact when I scanned channels I made sure to select GOTO POSITIONER. Hardware : Twinhan AD-SP400 support.zip Quote
newera Posted September 5, 2008 Author Posted September 5, 2008 I would like to add something to my previous post. In the root node of ASTRA and HOTBIRD the DISEQC dropdownlist is empty. When I tried to change it and click on UPDATE the new settings are not saved. I also click on SAVE to make sure that everything is saved for still it's not saved. When I scan I select USE POSITIONER and each channel is allocated a position which is the USALS position. However as I said the root does not have a correct position. It is empty. Thanks Quote
