Change the signal strength status refresh rate?
antdude
Hello!
I noticed in DVBViewer TE, it updates like every few seconds, but Pro v3.9.2.0 takes longer like ten seconds. How can I change Pro's refresh rate to faster updates since I hate waiting ten seconds for an update while tweaking my antennae.
Thank you in advance. :angry:
  • 3 months later...
No one knows? :) I upgraded TE too, and now it refreshes slow too. :)
Hardcoded. Not possible. The slow refresh rate avoids problems with faulty drivers causing a high CPU load when querying them too often for signal strength/quality.
Is there an addon, a third party program, or something to check signal strengths? I hate waiting about 15 seconds to see how good my signals are when adjusting my huge bowtie antenna for my two Broadband Technologies Air2PC-ATSC-PCI HDTV tuner cards (r0.2; DVB). :) Edited by antdude
You can use this:
http://www.quantexzone.com/files/scbda/Sca...nnelsBDA_UK.exe
if you want "quick" signal statistics, but be aware that even if the application reads them quickly, there's no guarantee that the driver is reporting them immediately. I think there is something like 5 seconds delay for eMPIA devices between the strength/quality changing and this being reflected in the driver's BDA signal stats.
(And then of course some drivers report absolute nonsense too)
Edited by CX23882-19
You can use this:
It didn't work for my two cards:
ScanChannelsBDA starting
Mon Dec 29 13:01:44 2008
Build - v2.7.0.0
Checking for new BDA DVB-T Cards
No cards found
Could not find any BDA devices. Check that drivers are installed and that the TV tuner is connected to your PC.
