gehru Posted September 7, 2008 Posted September 7, 2008 I have an experiment, uses IPTV Network Device in DVBViewer to receive BS TS Packet. Now I am may use DVBViewer to look at the BS television program, but discovers two questions: 1. is unable normally to displayer Japanese EPG. 2. DVBSource 3.2 is unable successfully to separate the Audio, but DVBSource 3.0.1 actually may succeed separates. The BS television specification is the ISDB-T. program compression specification is MPEG2 + AAC. Quote
hackbart Posted September 7, 2008 Posted September 7, 2008 Could you create a whole transponder dump? In this way we could be able to trace the problem. Christian Quote
gehru Posted September 7, 2008 Author Posted September 7, 2008 Could you create a whole transponder dump? In this way we could be able to trace the problem. Christian Because TransEditiptv.exe cannot let my Record, therefore I use other Program to take down bs-15 Transponder. have three programs frequency channels, bs hi, bs1 and bs2. ts by other (Abort 45M) Simultaneously I also provide following: Two TransEditiptv Screenshot screen 1 screen 2 one ini file which outputs by TransEditiptv imi file by TransEditiptv one CSV file which saves down by TransEditiptv CSV file by TransEditiptv one channel tS file which recording by DVBViewer ts by DVBViewer(abort 22M) Quote
gehru Posted September 7, 2008 Author Posted September 7, 2008 Again increases a file XML File by Transeditiptv Quote
hackbart Posted September 7, 2008 Posted September 7, 2008 Thanks the interesting thing is that the character table is defined as 0x1B, which is according to the specs (ETSI EN 300 468 V1.7.1) reserved for the future. We keep you informed here. Christian Quote
y_naka Posted September 8, 2008 Posted September 8, 2008 (edited) Hi,Nice to meet you I use DVBViewerPro in Japan. I am supplementary, but BS is ISDB-S not ISDB-T because it is a satellite television. ARIB(http://www.arib.or.jp/english/html/overview/sb_ej.html) has the details of a standard used in Japan. Edited September 8, 2008 by y_naka Quote
y_naka Posted September 8, 2008 Posted September 8, 2008 But the parameter of the video audio system changes in the middle of a program in ISDB. In the sound, there is monaural/stereo/dual stereo/dual monaural/5.1ch. On a video, it is 1920*1080(ISDB-S) / 1440*1080(ISDB-T) /720*480. In addition, there is the mobile broadcast of H.264 in ISDB-T, too. I can upload TS of ISDB-T if you are necessary. Quote
gehru Posted September 8, 2008 Author Posted September 8, 2008 Hi,Nice to meet youI use DVBViewerPro in Japan. I am supplementary, but BS is ISDB-S not ISDB-T because it is a satellite television. ARIB(http://www.arib.or.jp/english/html/overview/sb_ej.html) has the details of a standard used in Japan. Yes, the BS television specification is ISDB-S, I wrote wrong. Quote
