minix Posted September 9, 2008 Posted September 9, 2008 my setting : Vista 32Bit SP1 ATI 4850 ATI CATALYST 8.8 EVR Cyberlink PowerDVD8 support.zip : http://www.sendspace.com/file/jkmonw Because when I watch HD Jade channel(Hong Kong) with DVBViewer , sometimes the screen appear some blocks . So , can you optimize h.264 format of HD Jade channel(Hong Kong) in DVBViewer to solve the problem. Then your DVBViewer software will increase distribution. The following files are h.264 file of HD Jade channel(Hong Kong). http://www.sendspace.com/file/1so73e http://www.sendspace.com/file/di051k Quote
Derrick Posted September 9, 2008 Posted September 9, 2008 ..no problem with playback. Use another H.264 filter (e.g. cyberlink PDVD8 or arcsoft). Quote
minix Posted September 9, 2008 Author Posted September 9, 2008 Thanks your reply. Mostly playback the ts file of HD(h.264) is no problem, whereas watch the digital TV in live have this problem. And if you use another H.264 filter (e.g. cyberlink PDVD8 or arcsoft) with hardware acceleration of ATI AVIVO, the problem will increase. So , could you analyze the files and fix it to increase play and playblack stable . Quote
Valts Posted September 10, 2008 Posted September 10, 2008 Try Cyberlink .264 decoder from powerdvd 7. File version is 2.0.0.1904 Maybe this will be helpful for someone - there is a real chaos with different builds of the cyberlink decoders. I have had various results with them from 1) early builds (one that came with dvb card) - dxva not working at all 2) "stable" - this 1904 version I got by running update from cyberlink's site. 3) experimented with new builds (from dvd8) - working on some channels, throwing discontinuties, crashing system on others... codec hell pretty much... If you got loads of cpu power (quad) you can try using pure software solutions. Quote
minix Posted September 10, 2008 Author Posted September 10, 2008 (edited) I provide another file to you . I play this file with CoreAVC is no problem and play with powerdvd8 ultra(enable AVIVO Hardware Accelerator) is appear some blocks(above pic). the another file: http://www.sendspace.com/file/2m14y6 Edited September 10, 2008 by minix Quote
Valts Posted September 10, 2008 Posted September 10, 2008 (edited) I provide another file to you . I play this file with CoreAVC is no problem and play with powerdvd8 ultra(enable AVIVO Hardware Accelerator) is appear some blocks. the another file: http://www.sendspace.com/file/2m14y6 As it was said - it's not a DVBViewer related problem. Edited September 10, 2008 by Valts Quote
