Strange Scanning Problem with DVB Viewer 3.9
Makaronen
I have a FloppyDTV-C and have Comhem sweden as my TV-Supplier...
I got the latest MCE driver from DE installed for Windows TV Pack Fiji installed on my Vista Ultimate 64bit system...
I search the channels i Vista MCE and i found every channel except the HD Channels....
Thats the reason i also want DVBViewer to watch HD Channels....
When i have stopped the TV in Vista MCE and closed it down and scanning for channels with DVBViewer
i got a error message something like this: (VON ADRESE FFFFFFF VON ADRESSE FFFFFFF.)
But the weird is if i click aprox 5 times on the scan button it suddenly starts searching channels...
DVBViewer then founds channels BUT when it comes to 100 % DVBViewer Freezes and the only
way to close the program is to force it down with task manager... When it Freezes theres a new error message like:
(VON ADRESE MSVIDCTL.DLL) The scan does not save the channels when i have forced DVBViewer down.
I Know MSVIDCTL.DLL is a very important file for Directshow tv and i think Vista lock this file even if i stopped TV in MCE.
Anyone has a clue what to do ??
Edited by Makaronen
Pleas try the BDA (not MCE driver) do you get the FFFFFFF error in this case to?
Other users with my set of system can use DVBViewer with the MCE driver...
DVBViewer should work with the MCE driver right ?
If i switch to the BDA Driver i cant use MCE anymore.....
May be it work. But it is not officel supported.
Can you replace the diver for a test. And look if the problem still exists? There are three other user with the FFFFFFF error at the channel scan but all with DVB-T devices.
My be that help to find an solution for this problem.
Sure i will give it a try after work...
Hi !
Yesterday i tried to install the BDA driver with no luck...
I Uninstalled the MCE driver first and made a reboot...
Installed the BDA driver, but after the installation there is a exclamation mark in
devicemanager for my FireDTV TV Tuner.... And there is a message that windows could
not load the driver...?
Installed the MCE driver again and i am back at the beginning...
Could it be the MCE TV Pack who is the problem or what ?
I do not know.
  • 3 weeks later...
Hopefully in the current BETA 3.9.4.70 the problem is fixed.
Change: BDA direct tuning mode: In direct tuning mode an internal network provider is now used instead the MS NP. Hopefully this will help with the $FFFFFFF Error on some x64 Vista systems.
http://www.DVBViewer.info/forum/index.php?...st&p=214283
Activate Options > Hardware > Direct tuning
