willy k Posted September 12, 2008 Posted September 12, 2008 how to install remote control from TT Budget 3200 card on DVBViewer ,tnk ;) Quote
willy k Posted September 13, 2008 Author Posted September 13, 2008 (edited) works very good Technotrend Remote Input Plugin 1.1 ----------------------------------- This Plugin enables you to use the remote controls of Technotrend cards directly with the DVBViewer Pro. Installation: - Extract the archive into the DVBViewer Pro folder. - Start DVBViewer und choose options -> Input -> Input Plugins - You should see the "Technotrend remote" plugin in the plugin list. - Activate it by checking the box in front of the plugin name. - Select settings (button on the lower right). This shows the settings dialog of the plugin. - In this dialog select the device you want to use. Leave the dialog by pressing OK. - Now you can learn the remote keys in the "Input" section of the DVBViewer options. add on the text : learn your remote control the task function Edited September 13, 2008 by willy k Quote
Zasso Posted October 27, 2008 Posted October 27, 2008 works very good Technotrend Remote Input Plugin 1.1 ----------------------------------- This Plugin enables you to use the remote controls of Technotrend cards directly with the DVBViewer Pro. Installation: - Extract the archive into the DVBViewer Pro folder. - Start DVBViewer und choose options -> Input -> Input Plugins - You should see the "Technotrend remote" plugin in the plugin list. - Activate it by checking the box in front of the plugin name. - Select settings (button on the lower right). This shows the settings dialog of the plugin. - In this dialog select the device you want to use. Leave the dialog by pressing OK. - Now you can learn the remote keys in the "Input" section of the DVBViewer options. add on the text : learn your remote control the task function Hi I installed the plugin and set the TT remote, but I don't understand how can "learn" the function. Could you please help me? Regards Quote
