KingBoyD Posted September 12, 2008 Posted September 12, 2008 Hi! First I have to say I have been very satisfied with DVBViewer for more than a year now. But suddenly I have an annoying problem. If I start a recording (timer or direct) and then start to watch that recording while it's still recording I can only watch as long as the recording is and then it stops. For example, if I start a recording at 8.00 and start watching it 8.03 the playing stops after 3 minutes. If I then open the recording again 8.10 I can watch 10 minutes and then it stops. The recording is recording as long as I have set it up in the timer or until I stop it myself so thats no problem. This has worked for me for over a year and its very annoying since I use this feature a lot. I upgraded to 3.9.4 this summer and maybe it's this version but I think that this worked after I updated and that it has stopped later on. I have also installed a new DVB-T card but how could that be in conflict? I'm running Vista. Please help me! Quote
KingBoyD Posted September 12, 2008 Author Posted September 12, 2008 I have now tested this with 3.9.2 and it works perfectly. Do I have to do anything special to make this work in version 3.9.4? Quote
Griga Posted September 12, 2008 Posted September 12, 2008 Go to Options -> DirectX. Is the DVBViewer Filter (DVBSource) selected for MPEG playback? Quote
KingBoyD Posted September 12, 2008 Author Posted September 12, 2008 Go to Options -> DirectX. Is the DVBViewer Filter (DVBSource) selected for MPEG playback? Yes! But I am recording in .ts and always have. Quote
Griga Posted September 12, 2008 Posted September 12, 2008 TS is a MPEG container format. So it should work. Have a look at View -> Filters when playing an ongoing recording. Is DVB Source listed there? Quote
KingBoyD Posted September 12, 2008 Author Posted September 12, 2008 TS is a MPEG container format. So it should work. Have a look at View -> Filters when playing an ongoing recording. Is DVB Source listed there? Yes, DVB Source is listed. Quote
Griga Posted September 12, 2008 Posted September 12, 2008 I can't see here why it doesn't work. Try to play the recording with the TSPlayer from the members area -> tools section. Same problem? Quote
KingBoyD Posted September 13, 2008 Author Posted September 13, 2008 I can't see here why it doesn't work. Try to play the recording with the TSPlayer from the members area -> tools section. Same problem? I've tried TSPlayer now and that works. But it still doesn't work in DVBViewer. And as I stated before, it works if I change back to version 3.9.2. Any ideas? Quote
Tjod Posted September 13, 2008 Posted September 13, 2008 Pleas start the DVBViewer via start menu > programme > DVBViewer > Support > DVBViewer Pro (Debug Mode) and reproduce the problem 2-3 times. And than Post a support.zip Quote
KingBoyD Posted September 15, 2008 Author Posted September 15, 2008 Ok, here's a support.zip. Hope this is what you're looking for. Never done this before. support.zip Quote
Tjod Posted September 15, 2008 Posted September 15, 2008 Hope this is what you're looking for.Yes, but i got no idea what reason for your problem is. Quote
Griga Posted September 15, 2008 Posted September 15, 2008 Strange thing. I've tested it - here it just works.Seems the size of the recorded file is not updated continuously in DVBViewer... maybe the Windows function that is used to query the size ignores further changes, for whatever reason. Again try TSPlayer. Does it update the file size shown above the position slider continuously? TSPlayer won't stop read attempts, even if the file position reaches the displayed file size, so it will play the part beyond it (if there is any). In contrast to TSPlayer, DVBViewer tries to determine whether it is a growing file or not. If the file size does not change, DVBViewer stops playback when the file position reaches the (assumed) end of the file. What about the duration shown in the DVBViewer control bar? Is it increasing? Quote
KingBoyD Posted September 16, 2008 Author Posted September 16, 2008 Strange thing. I've tested it - here it just works.Seems the size of the recorded file is not updated continuously in DVBViewer... maybe the Windows function that is used to query the size ignores further changes, for whatever reason. Again try TSPlayer. Does it update the file size shown above the position slider continuously? TSPlayer won't stop read attempts, even if the file position reaches the displayed file size, so it will play the part beyond it (if there is any). In contrast to TSPlayer, DVBViewer tries to determine whether it is a growing file or not. If the file size does not change, DVBViewer stops playback when the file position reaches the (assumed) end of the file. What about the duration shown in the DVBViewer control bar? Is it increasing? In DVBViewer 3.9.4, where the length of the recording is shown (bottom right), it displays a fixed figure. It doesn't increase. And when the playback has reached the end of the file it stops although the recording is still ongoing. In DVBViewer 3.9.2 the same figure increases and the playback doesn't stop. Quote
KingBoyD Posted September 16, 2008 Author Posted September 16, 2008 Yes, but i got no idea what reason for your problem is. I don't understand what you mean. What should I do more? I have tried to explain what is not working for me and I have uploaded a support.zip as you asked for. Please explain so I can give you what you need. Quote
Tjod Posted September 16, 2008 Posted September 16, 2008 I don't understand what you mean. What should I do more?I have no idea what the reason for your problem is. I try to reproduce your problem. But on my PC Timeshift work normal. Quote
KingBoyD Posted September 16, 2008 Author Posted September 16, 2008 Strange thing. I've tested it - here it just works.Seems the size of the recorded file is not updated continuously in DVBViewer... maybe the Windows function that is used to query the size ignores further changes, for whatever reason. Again try TSPlayer. Does it update the file size shown above the position slider continuously? TSPlayer won't stop read attempts, even if the file position reaches the displayed file size, so it will play the part beyond it (if there is any). In contrast to TSPlayer, DVBViewer tries to determine whether it is a growing file or not. If the file size does not change, DVBViewer stops playback when the file position reaches the (assumed) end of the file. What about the duration shown in the DVBViewer control bar? Is it increasing? I just tested TSPlayer and it updates the file size continously as well as the length of the recording so it is working as it should . Quote
KingBoyD Posted January 13, 2009 Author Posted January 13, 2009 (edited) Hi again! I have to open this thread again. I have now installed Vista Ultimate from scratch and also installed DVBViewer 4.0 with the same result as with 3.9.4. Again I can't watch an ongoing recording. It's exactly the same problem as I have described earlier but with 4.0. 3.9.2 works great. Except from Vista the only program I have installed so far is PowerDVD 8 and DVBViewer. [Deleted] Please, if you have any more input or suggestions what to test. I was really hoping for the new 4.0 but since this doesn't work either I'm starting to loose hope... Edited January 13, 2009 by Griga Violation of forum rules Quote
Griga Posted January 13, 2009 Posted January 13, 2009 if you have any more input or suggestions what to test. Yes. - Try DVBViewer GE (see members area, read the ReadMe!). Same problem when recording with DVBViewer GE? Since DVBViewer GE doesn't support CI/CAM, you will have to use a free channel for testing. This will be quite revealing, since in comparison to DVBViewer Pro DVBViewer GE is more similar than TSPlayer. - Try to play a radio recording (no video) with DVBViewer Pro. Same problem? Somehow DVBViewer doesn't recognize that the file size is growing. Most likely due to very special conditions, since you are the only one reporting this issue up to now. Nevertheless I would like to know the reason... Quote
KingBoyD Posted January 14, 2009 Author Posted January 14, 2009 Just tried to do the same thing with a radio channel and that works fine. Will test GE later. Quote
KingBoyD Posted January 14, 2009 Author Posted January 14, 2009 Tried GE and it works as well. So it's something different with Pro version! Any more info I can give you to helpp you find the problem? Quote
KingBoyD Posted January 14, 2009 Author Posted January 14, 2009 I know that something that worked in version 3.9.2 is not working in later versions (3.9.4 and 4.0) with the exact same environment. What has changed since 3.9.2? What does 3.9.4 and 4.0 have/not have in comparison to GE and TSPlayer? Quote
KingBoyD Posted January 14, 2009 Author Posted January 14, 2009 If I record in 4.0 and then watch in GE version it also works fine but how much fun is that? Quote
Griga Posted January 14, 2009 Posted January 14, 2009 Wait - I have a rough idea now what may go wrong, and I'll contact the Pro devs (I'm only responsible for GE & TSPlayer). Quote
Lars_MQ Posted January 14, 2009 Posted January 14, 2009 start -> programs -> DVBViewer program group -> support -> DVBViewer (Safemode). Does it work then? Quote
KingBoyD Posted January 14, 2009 Author Posted January 14, 2009 When I run in safe mode I get no picture. Could it be that the plugin [removed] is not activated in safe mode? there is no plugin menu. However, if I try to record anyway and try playing the file it says that the file is being used by another program. § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not. Quote
Tjod Posted January 14, 2009 Posted January 14, 2009 Could it be that the plugin is not activated in safe mode?Yes, if there is no problem in the safe mode, the problem is caused by a plugin. Remove the plugin or ask the plugin Author about it. Quote
KingBoyD Posted January 19, 2009 Author Posted January 19, 2009 I sincerely apologize for taking your time. I really didn't think that the problem could be the plugin but I have now tested this with my original card directly in the CAM/CI and it works. Will search for the answer somewhere else. Quote
