T079142 Posted September 13, 2008 Posted September 13, 2008 I have been used TT-3650 USB together with DVBViewer with good result. Now I have problem with some HD channels with high bandwith I bought a new card TT-S2-3200 that should handle the high bandwith. After installation I have tried to use both DVBViwer pro and TT-light version with the same result. Scanning for channels works good even the HD-channel with the high bandwith are found. The CA is found , but I can't find any video or sound. The only time I suceed is if I restart the comuter and use a non cryped channel, then it works for 10 sec. and then the signal is "frozen". I use Vista 64 together with the latest driver for the card. What have I missed ????? Thankfool for help Quote
T079142 Posted September 13, 2008 Author Posted September 13, 2008 Sorry Imissed to send the support file support.zip Quote
