trifon33 Posted September 13, 2008 Posted September 13, 2008 (edited) Hi all, On the french encrypted terrestrial DVB, the encrypted chanels(H264 SD) switches from H264 to Mpeg2 during FTA period. I have not found any DVBViewer feature to follow this peculiar chanels behavior. Edited September 13, 2008 by trifon33 Quote
Derrick Posted September 13, 2008 Posted September 13, 2008 ..dunno whether "Auto-Update Channel" will follow the stream type change. Quote
Griga Posted September 13, 2008 Posted September 13, 2008 If auto channel update is switched on, at least DVBViewer GE should respond to a MPEG2 <-> H.264 change by retuning and rebuilding the filter graph, provided the PMT (broadcasted Program Map Table) signals the change correctly. I guess it's similar in DVBViewer Pro, but I never had a chance to test it. Quote
Derrick Posted September 13, 2008 Posted September 13, 2008 ..some data would be useful. @trifon33 could you open the transponder with transedit -> analyze -> save as xml, and post the result. To reduce the file size, please uncheck -> read EIT in the settings for the analyzer. It could be that the stream type is mpeg2 though the content of the scrambled stream is h.264. A special viaccess module then will descramble and transcode the stream to mpeg2. Quote
