The Audio Recorder plugin and a suggestion
I'm a big fan of the Audio Recorder plugin and it fabulously satisfies my varied recording needs. However, I wish to see the following feature implemented in it:
The ability to press its buttons (such as Start/Stop and Pause/Go on) directly from the DVBViewer window in -- in addition to the plugin window itself. That would make life a lot more easier. This can also be designed as a user-configurable feature -- "Display plugin buttons in the DVBViewer window".
Also, I'm using Lame_enc.dll V3.98 -- the latest release -- with Audio Recorder. Does the plugin work well with it or should I downgrade to V3.92?
All the best
