bob0r Posted September 15, 2008 Posted September 15, 2008 How can i select a certain encryption on a channel? Many new HDTV channels have multiple encryption, how can i force DVBViewer to use card X instead of card Y? Quote
Tjod Posted September 15, 2008 Posted September 15, 2008 This is the Part from the CAM it should select the encryption based on the Smartcard. The DVBViewer tells the diver from the TV card/CI only which channel (PID) should be decrypted. Quote
Lars_MQ Posted September 15, 2008 Posted September 15, 2008 Youcan use the channel groups to direct the channels needing card B to it. In the hardware options define for one device (lets call it device 1) channel group A and deselect channelgroup B. The other device (device 2) select Channelgroup B and deselect channelgroup A. Now you go into the channel editor and assign all channels needing device 1 the channelgroup A and alle needing device 2 the group B. Quote
