Codec issue with Hauppauge HVR4000 / DVBV 3.9.4
Araj
After updating to DVBViewer 3.9.4, I have a problem with the video display codecs. I have a selection of different codecs (most of them from Cyberlink, bundled with the card) and strangely none of them will work for all the transponders I use.
I have DVB-T plus a 3-LNB S2 setup (Astra 19.2 and 28.2, Hotbird 13), my tuner card (for dvb-t and s) is the Hauppauge HVR 4000. Whatever codec I choose now in options, it doesn't work for all 4 sources - although I can get all souces to run if I change the codec.
Does someone have 3.9.4 running fine with the HVR4000 - if so, please let me know which codec you're using !
Thanks !
