dorijan Posted September 17, 2008 Posted September 17, 2008 Hi... I am using windows 2008 server, and have a problem that DVBViewer does not detect any dvb-t card. I have 2 cards (one pci and one usb) and ss2 card. SS2 has been detected without problem, but this 2 does not detect. I also used this cards in windows xp and windows 2003 server and they worked without problem with DVBViewer. Any suggestion will help Quote
Tjod Posted September 17, 2008 Posted September 17, 2008 Microsoft has removed the BDA Driver support in windows 2008 server. You need files from other windows installations. http://www.google.com/search?hl=en&q=w...2008+server+bda Quote
dorijan Posted September 17, 2008 Author Posted September 17, 2008 Microsoft has removed the BDA Driver support in windows 2008 server. You need files from other windows installations. http://www.google.com/search?hl=en&q=w...2008+server+bda thx...I am trying it now...but its not that simple.. It is hard to find someone who has windows vista 64 bit Quote
