boulder2 Posted September 18, 2008 Posted September 18, 2008 I have 2 PCI cards in my PC : a Technotrend Budget S2-3200 with CI module and Aston CAM 1.07 2.18, and a Hauppauge Nova HD S2 (no CI used yet). Now it seems that I cannot tune any of the Flemish channels (TV Vlaanderen channels) : VTM, 2Be, één, Ketnet/Canvas, Vitaya, KanaalZ, etc. Although the ones that are in the Canaldigitaal package can be tuned and decrypted : NED1, 2,3, één HD, VOOM HD, BravaHDTV, ... All channels can be tuned with the TT Mediacenter, so I doubt this is a hardware problem. Technotrend Budget S2-3200 driver 5.0.0.19 Asus P5W DH Deluxe Nvidia Geforce 7950GT driver 6.14.11.6921 Also, I wonder : is there any way to enable the DUAL system on this Aston CAM ? Normally, I should be able to record from 2 different stations with a single tuner if they are on the same transponder, because the CAM can handle this load. But DVBViewer does not let you do so. Quote
CiNcH Posted September 18, 2008 Posted September 18, 2008 Your TT-API DLL is pretty old, so go for an updated one. When installing the DVBViewer you can chose to download components where it is possible to add TT support. This will download a recent version. Also VC2005 SP1 runtimes have to be installed for the DLL to work. Quote
boulder2 Posted September 18, 2008 Author Posted September 18, 2008 Your TT-API DLL is pretty old, so go for an updated one. When installing the DVBViewer you can chose to download components where it is possible to add TT support. This will download a recent version. Also VC2005 SP1 runtimes have to be installed for the DLL to work. I got it now. I think it was related to using the latest beta. I returned to an older beta, and rescanned the TV Vlaanderen channels, and found that the Stream ID was different (1119 vs 1116). Must have been due to transponder files being overwritten. Quote
