vaio6 Posted September 19, 2008 Posted September 19, 2008 I am a registered user but registration window pops out once in a while and shuts the program down... any fix? thanks Quote
vaio6 Posted September 19, 2008 Author Posted September 19, 2008 Pleas post your support.zip. sorry and here you go, thanks support.zip Quote
Tjod Posted September 20, 2008 Posted September 20, 2008 There is a problem with the Copy protection. You have to Uninstall the DVBViewer via Control Panel > Software including the configuration folder. Than reinstall the DVBViewer again with you usernam and password. This should fix your problem. Quote
