EPG on one channel has disappeared
Stephen
I use DVBViewer to watch the free-to-air channels on Astra 19.2E. Two or three weeks ago however the EPG on one particular channel (Italian channel Rai Uno) stopped updating and has been blank ever since. I assume something must have changed with that channel (as I hadn't altered any DVBViewer settings), but I have no idea whether it's possible to fix this. As an aside, although it's not related to this issue, one other channel (TVEi) has never had any EPG info, it would be nice if I could work around that one too.
Any suggestions would be greatfully received.
Thanks in advance,
Stephen.
Try a rescan with update, broadcasters change their details from time to time
Tried that - No luck. Thanks for the suggestion though.
You can't fix at all... the RAI Uno EPG info simply aren't transmitted from Astra 19.2 anymore...
and no one can know if they whould transmit it again in the future, right now RAI is changing many things...
Anyway you can find the info on this web page...
:D
