hajj_3 Posted September 21, 2008 Posted September 21, 2008 (edited) Need some help, i get the following error once scanned for channels, no video or audio will display: here are my settings: I've tried changing mpeg2 decoder to ffdshow and audio to powerdvd but neither helped. I tried Transedit and the preview works fine on there but not in DVBViewer. Hope someone can help as Hauppauge Wintv application is AWFUL and crashes quite often, im from England, UK using: Hauppauge Wintv Nova-TD Stick with terrestrial aerial. Edited September 21, 2008 by hajj_3
hajj_3 Posted September 21, 2008 Author Posted September 21, 2008 (edited) attached is the .zip this is my tv card: http://www.scan.co.uk/Product.aspx?WebProductId=529784 support.zip Edited September 21, 2008 by hajj_3
Lars_MQ Posted September 21, 2008 Posted September 21, 2008 No support for thieves. Come back, when you have a legal version of the DVBViewer Pro. Closed.
hajj_3 Posted September 21, 2008 Author Posted September 21, 2008 regarding the following post i made: http://www.DVBViewer.info/forum/index.php?showtopic=29572 why would i purchase DVBViewer on the off chance that it might work with my tv card? my tv card isnt in the supported list which is why i used a cracked version to see if my card would work, if it will work i'll happily buy the software but i'm not paying for something that i dont know will work. If you can buy the tv card and verify it works and add it to supported hardware list i'll happily buy this software or if you can help me get the app to work with my tv card i will buy it but theres no chance i'm paying for software that might not work. hope to hear back from you soon, regards.
Tjod Posted September 21, 2008 Posted September 21, 2008 There is TransEdit MMC http://www.DVBViewer.com/en/index.php?page=downloads for test is the hardware work. And yes the Hauppauage Nova-TD work i use it. You have to remove the faultily cracked compline from you system (including all configuration files) before you install the Legal version.
