vondoogle Posted September 22, 2008 Posted September 22, 2008 (edited) I managed to get the motor going in the end after following mr Chalea advise of using discq.exe to build the strings to overcome the bug with western sats in DVBV Pro, anyway when I change channels on another sat the picture does not display, the motor will move fine. I have no signal level or other info in the bottom bar, if I rebuild the graph then the picture will display and I can change channels within the same sat, but when I move to another sat then the problem starts again until I rebuild the graph. Any ideas what might be causing this? My System is: Technotrend budget S2-3200 PCI Card Asus P5E-VM HDMI MB Intel E8500 core duo 2GB ram Vista Ultimate SP1 DVBV 3.9.4.0 Edited September 22, 2008 by vondoogle Quote
Valts Posted September 23, 2008 Posted September 23, 2008 Believe one of suggested solutions was to set 'retune on missing stream' in the hardware options. Quote
vondoogle Posted September 23, 2008 Author Posted September 23, 2008 Believe one of suggested solutions was to set 'retune on missing stream' in the hardware options. Cheers, set it to 3 seconds and all sorted Vondoogle Quote
newm Posted September 12, 2009 Posted September 12, 2009 i have same prob as this but rtune did not work for me tried everything just cant sort it my specs are amd phennom x4 ati radeon 32oo built in hdmi win 7 x64 floppydtv s2 msi mobo 4gb ram did have it all working but had to change my mobo and now have this prob can any1 help please Quote
humando65 Posted October 29, 2009 Posted October 29, 2009 Hello, Same problem with me too. To avoid double posts, check the subject here: http://www.DVBViewer.info/forum/index.php?showtopic=36189 Thanks. Quote
