steve4063 Posted September 28, 2008 Posted September 28, 2008 I:\ProgramData\CMUV\DVBViewer\support.zip attached i think is the support file thing please can someone sort it out i am having loads of trouble it keeps crashing this program and my pc it will only open as admin it says sometimes no hardware (think it might be sorted now) when it is running it'll shut itself down and windows will say there was a problem and it had to shut it down or it'll ask for the password again and then shut it self down if i try and teach the remote anything or after i've tried to alter anything in the options it'll crash itself i am using a satelco easywatch hdtv usb cI sat dvb-s2 receiver i use vista 64 graphics is radeon x1650 not sure what the chipset means or is sorry anymore info please ask and explain how to find out many thanks support.zip Quote
TeaTray Posted November 4, 2008 Posted November 4, 2008 It's interesting that no-one has replied to this. It appears to be a problem with 3.9.4 & vista 64. I had the same problems, for the most part, and resolved them by downgrading to 3.9.2 :-(I wrote to the developers (Christian Hackbart) who suggested that I may have previously used an illegal version, which wasn't so. When I discovered that the problem doesn't exist with 3.9.2, but only 3.9.4, I informed him but, so far, got no reply. BTW It would always crash if I didn't deal with the registration dialogue. Whether I filled it in correctly or cancelled it, it would close DVBViewer and would start agin for a short time, before repeating the process. :-(Here is the my mail to Christian from 31st October, with all the previous mail quoted, below it (BTW obviously when I mention 2.9.4, at one point, I meant 3.9.4 - just a typo):CH> This usually only happens if you have had a non legal version earlier. ToCH> remove this, select under help->config folder the configuration folder.CH> Close the DVBViewer, deinstall it and remove the remaining entries in theCH> config folder. After this install the DVBViewer regular.In this case, not. I definitely never used any illegal version, ever. Ifollowed your instructions, with version 3.9.2 and the problem nevershowed up again.Then, I upgraded to 3.9.4 and the problem was back. This is all verytime consuming, because I have to tweak everything on a re-install toget all my settings back the way they were, originally.Please help. I want the features of 2.9.4 (actually I want the nextversion, having read of the changes you are planning), but I cannot usea version that keeps nagging me for registration, when I am alreadyregistered.If there is anything more I can tell you about my installation that mayhelp, please let me know. I enclose support.zip.CH> -----Original Message-----CH> From: ***@*****.com [mailto:***@*****.com]CH> Sent: Sunday, October 26, 2008 2:04 AMCH> To: DVBViewer.comCH> Subject: Error on the forumsCH> I just can't understand it. In the last few days, DVBViewer is naggingCH> me for a username & password. It doesn't matter what I type in - evenCH> nothing. DVBViewer dies and when I restart it, it will, after a shortCH> time, nag me again. Of course I tried the name/pass combination you sentCH> me: username=ray@goaheadspace.com, but not only doesn't it work anyCH> more, but I can no longer log into the forums. What should I do? I haveCH> clicked that I forgot my password but it says it doesn't know me or myCH> email address, at all. I have been a registered user of DVBViewer forCH> some months now. Please, help.-------------------------------------Hauppage S2 HDVista 64ATI Radeon HD 3870------------------------------------- I:\ProgramData\CMUV\DVBViewer\support.zipattached i think is the support file thing please can someone sort it outi am having loads of troubleit keeps crashing this program and my pcit will only open as adminit says sometimes no hardware (think it might be sorted now)when it is running it'll shut itself down and windows will say there was a problem and it had to shut it downor it'll ask for the password again and then shut it self downif i try and teach the remote anything or after i've tried to alter anything in the options it'll crash itselfi am using a satelco easywatch hdtv usb cI sat dvb-s2 receiveri use vista 64graphics is radeon x1650not sure what the chipset means or is sorryanymore info please ask and explain how to find outmany thanks Quote
