DVBV Pro hanging
vondoogle
Found a little problem when feed hunting, and am not sure if there is an easy fix or need to report a bug. What happens is lets say I make a transponder scan on 10 east and watch a feed for a bit, then when I have moved away from that sat I decide to go back but the channel is no longer transmitting, then DVBViewer will crash, and I will have to restart the PC.
To get around this what I have had to do is the channel editer 1.5.1 and edit the channels.dat file to delete the transponder that no longer transmits. This is not really ideal as it would be better to have those TP in the channel list for next time.
So does anyone know if there is a work around or should I make a bug report?
Vondoogle
Always follow these instructions. Otherwise no one can - or wants - to help you!.
Scroll up.
Scroll up.
Well, before I posted it in bug reports and went with the support file etc, I was just asking a general question if this is normal behaviour for this program if it lands on a channel that is no longer there!
Vondoogle
