b20 Posted December 31, 2003 Posted December 31, 2003 I got my SS2 yesterday afternoon and ordered the Full version of DVBViewer. I first ran the Technisat CD install for drivers + DVBViewer TE. Everything went fine, and I got Fox in a minute. I made a scan to add Euro1080, and was able to display it without any issue. Excellent image on my 50" DLP. CPU usage was in the 18-20%. I then installed the full version of DVBViewer in a separate directory. When I run it, I get a jerky image with pixels. Switching to TE Edition, everything was back to normal. I would like to make sure that my FV has the same graph as my TE version. I was not able to get the TE graph with GraphEdit (latest release Aug03 and earliers too). What are the default settings of TE edition that make it working so smoothly and could be applied to FV to achieve the same results ? Quote
Guest Oliver Posted December 31, 2003 Posted December 31, 2003 At first you should post your setup.ini located in the DVBViewer folder as an attachment. Bye, Oliver Quote
Griga Posted December 31, 2003 Posted December 31, 2003 Check Settings/ Options/ DirectShow Filters/ DVB Source. Probably "Auto" is selected as Videocodec, letting the DVBViewer select some Videodecoder that is not suitable. Change to DVD Express Videodecoder and perform View/Rebuild Graph. Griga Quote
b20 Posted January 2, 2004 Author Posted January 2, 2004 At first you should post your setup.ini located in the DVBViewer folder as an attachment. Bye, Oliver Here are the setup.ini files which have been renamed as setupTE.ini for the one in C:\Program Files\DVBViewer TE setupFV.ini for the one in C:\Program Files\DVBViewer SetupFV.ini Quote
