Reset Display Settings
avoidz
Hi, is there a way to reset the Display Settings (Video settings) to their default values?
Cheers :blink:
Edited by avoidz
May be the Default button?
Edited by Tjod
Does your screenshot show the Default settings? with the Brightness level slightly higher? I figured the Default button was a "set as" type control, since I remember raising the brightness there a while ago.
Otherwise, I'm wrong and it's really as easy as hitting that Default button!
Cheers :blink:
