DVBViewer 3.9.4
dan97
Hi
I come from HK and using compro pci-e card for receiving the DVB-TH signal. First, I want to clarify no lagging or skip frame issue when I use the player come with the card.
My issue is. when i see the HD channel in HK. at the beginning, it seems quite normal, and then after a while, it then becomes not so smooth. i.e kind of skipping a few frame during displaying
any idea how I can track down this issue?
I am using XP, ATI HD2600 based graphic, I have powerdvd installed and using it for hardware decode.
Danny
Hi
Danny
Hi!
What is your model no. of Compro PCI-E Card? Is it TH350i? I found it is not unstable on Vista. You see my issues referring to the link : http://www.DVBViewer.info/forum/index.php?...mp;#entry213433
BigToad
same brand but it is 850 model. i am using xp not vista. btw, the Dtv dtvplayer play it smoothly
just svbplyer at HD mode seems having problem
