DVB-S2 signal Problem!
Deviance
Hi, I have Skystar HD2, (mantis BDA driver), and I can't get HD channel (dvb-s2 or 8psk) on hotbird and eutelsat w3. I can get QPSK signal. Also transedit can't get signal. The other dvb aplication does. What is the problem? I tried DVBViewer 3.9.4.xx beta versions, but the result is the same. NO 8PSK signal..... :bye::D:)
...and also I have tried it changing transponder like this:
2=10880,V,17360,34,DVB-S2
3=10928,H,30000,23,DVB-S2
..and like this:
2=10880,V,17360,34,|DVB-S2
3=10928,H,30000,23,|DVB-S2
...and like this:
2=10880,V,17360,34,5,1,|DVB-S2
3=10928,H,30000,23,5,1,|DVB-S2
but nothing change. Still no 8psk signal and no HD channel. Waiting your suggestions... Thanks..
what is your system (xp, vista32, vista64), how many ram?
skystar hd2 will not run with vista64 sp1 and 4 or more GB ram.
Hi, I have Asus M2n-32slı delux mainboard, AMD phenom 9500 QuadCore, 4 GB ram, 2 x 512 GB harddrive, Benq HDMI LCD monitor... and XP sp3 and vista ultimate 64bit. Skystar HD2 doesn't work under vista 64bit with SP1. So, I uninstalled sp1. But, under vista 64bit and xp, I couldn't manage to get any 8PSK signal. I have uploaded my support zip. Waiting for your suggestions.. Thanks...
Edited by Deviance
Hi, I could get 8PSK signal and have founded HD channels with Transedit_MMC_Demo, but it can't save channels after DVBViewer 2.1. ;):)
Hi, I have solved the problem by removing Diseqc switch. SO I can get signal from 8PSK transponders. Thanks anyway....
  • 1 month later...
Why, why why!!!???? B)
any workarounds yet????
Why, why why!!!???? :)
It runs fine in Vista SP1 64bit with the followin drivers. 1.1.300
Although i have a major problem regarding signal (while my previous ss2 was doing fine in that area) my skystar HD2 loses signal while i zap through channels and dvb-s2 works only for a few seconds.
