IRa Posted October 5, 2008 Posted October 5, 2008 Display settings button (equalizer) doesn't work anymore in 3.9.4, works still in 3.9.2 . Is that a bug or new design ? Quote
Lars_MQ Posted October 5, 2008 Posted October 5, 2008 Well most likely you use a decoder (AC3Filter or similar) to upscale stereo to 5.1. The EQ does only work for Stereo. Quote
IRa Posted October 5, 2008 Author Posted October 5, 2008 The EQ does only work for Stereo.I mean that by pushing the button it doesn't open the Video and audio settings (zoom, equalizer, saturation etc) window anymore. I can still select the same "function" from menus (settings/equalizer) Quote
IRa Posted October 13, 2008 Author Posted October 13, 2008 Display settings button (equalizer) doesn't work anymore in 3.9.4, works still in 3.9.2 . Is that a bug or new design ?I answer to myself. It does not work if selected video renderer is VMR7. With all other video renderer selection it works. However selecting the same window from menu (settings\equaliziser) it works also with VMR7. Is there some reason for that, so I am still curious if it is a bug or feature? Quote
