NetStreaming to WMP
atanas.bakalov
Hello Guys,
Is there a way, the NetStreaming plugin to stream to WMP (Windows Media Player). I understand that the WMP will only read the ASF container and not the TS.Is there an option on NetStreaming to change the container format ? Or maybe somebody have heard of a plugin for WMP, that will allow to play the output of the NetStreaming plugin ?
Thanks
WMP-> open URL :)
Derrick, this does not work. you know ...
..yes, it does. But you'd better take the VLC :)
Yes, i prefer VLC too :), but it has one limitation and that is why I have to use WMP.
The problem is that VLC does not support more than one ActiveX in a single html page, and this is something that is a must for the thing I'm doing.
Anybody knows how to stream to WMP with DVBViewer ?
