Hauppauge HVR 4000 WinTV-CI
Hello,
I have some problems to see WinTV-CI. After the installation of the driver, in the manual is written that:
Under device manager I should have wintv under USB resouces ando also wintv under Controller audio video and games. But I can see just wintv under USB resources. Is this a problem.
Of course under DVBViewer I do not have the possibiliti to choose CAM (It is always gray).
Ciao
Backville
No way,
also with DVBviwertest. DO you see wintv under hardware->device manager->audio video and games?
The manual says that I should hav ehtis entry, but I have only the entry under USB port.
Thanks
Ciao
Frodo
