HVR-4000 remote dvbviewer
OK I give in with this I have tried every ini file edit to get this remote to work please anyone got and remote ini file that works good
  • 3 weeks later...
I spent hours fiddling around with remote.ini too until I realised how ridiculously simple it is:
Assuming you have the Hauppauge remote driver installed
In DVBV, go to options --> input
Click on the Learn button
Click on the menu item you want to assign
Click the button you want to use for that on the remote
Bingo!
I can send you my remote.ini file if you like but I very much doubt it's the way you want it. Give the above a try and if you have no luck, let me know
