Bjur Posted October 13, 2008 Posted October 13, 2008 I have been using DVBViewer with XP for quite a time and now switched to Vista, but when I schedule a recording it shows up in scheduler but not in Vista task scheduler. What can be the problem? What will be the best to use scheduler or recording service? I'm not very familiar with recording service, but is it easy to setup and use vs. scheduler? Quote
thl Posted October 16, 2008 Posted October 16, 2008 Hello Bjur I have the exact same question. Have you found the answer ? Regards Thomas Quote
Bjur Posted October 26, 2008 Author Posted October 26, 2008 Hello Bjur I have the exact same question. Have you found the answer ? Regards Thomas No, anyone able to assist? Quote
