cbran Posted October 13, 2008 Posted October 13, 2008 Hello, I use Hauppauge WinTV HVR 4000 for satellite reception. In statusbar (or any other place it's set up to apear), the green bar, "signal quality" it's always constant (94%) no matter what channel freqency is tuned. I also use FastSatFinder where "signal quality" and "signal level" are both displayed. Quality is also constant (94%) for all frequences. Only the "signal level" is variable, as I move the dish or change transponder. Is there a way to have "signal level" displayed instead of "signal quality"? Is it a bug of DVBViewer or tuner driver? Thank you. Quote
Moses Posted October 14, 2008 Posted October 14, 2008 This is driver related. You better ask Hauppauge. Quote
cbran Posted October 16, 2008 Author Posted October 16, 2008 Yes, but Signal level acts normaly, depending on how well the dish is positioned. I mean I would like to see Signal Level instead of Signal Quality (wich for Hauppauge HVR 4000 is constant, and I guess it's the other way around for other tuner cards) displayed in DVBViewer. Quote
