greyghost Posted October 15, 2008 Posted October 15, 2008 is there a way to play vlc files in DVBViewer. This would be the bees knees. Thanks Quote
LeLung Posted October 15, 2008 Posted October 15, 2008 The DVBViewer supports mkv files, but only the unencrypted ones. Quote
greyghost Posted October 15, 2008 Author Posted October 15, 2008 The DVBViewer supports mkv files, but only the unencrypted ones. Thanks for the reply. Any idea how I get DVBViewer to play them from within the interface and how do I know if they are encrypted or not. Thanks Quote
Moses Posted October 15, 2008 Posted October 15, 2008 you have to add the ending mkv in options->movies. Then the OSD Video page should show the files (if you set up the folders correctly). Of course you need the correct direct show filters for the content of the file... for example you could use the haali mkv splitter as splitter and ffdshow to decode the content. Quote
