Advice on DVB-T usb card wanted
Bobben
I have a Terratec Cinergy DVB-T USB card which unfortunatly do not send
scrambled PIDs via USB. I would like to measure bitrates and record scrambled components with Transedit
but this is not possible due to the limitation in the Cinergy card.
Does anybody know about a USB DVB-T card that also transmits scrambled PIDs over USB to TransEdit ?
Normally those devices do not perform any filtering. Only the XE stick does. All USB 2.0 sticks transfer the whole TransportStream.
Will this one work with TransEdit ?
http://www.pinnaclesys.com/PublicSite/uk/P...TVnanoStick.htm
Technical Specifications
System Requirements:
* Microsoft® Windows® Vista (32 bit) or Windows XP with latest Service Pack
* Intel® Pentium® 4 2 GHz, Pentium® M 1.3 GHz or equivalent AMD® Athlon® XP1
* Windows XP: 256 MB RAM (512 MB recommended); Windows Vista: 512 MB RAM (1 GB recommended)
* UDMA/IDE hard disk with min. 5 GB free capacity
* Graphics /sound controllers with support for DirectX® 9 or higher
* Free USB 2.0 port
* DVD drive or burner
* Internet connection for software updates and activations
1HDTV support requires a dual core processor with minimum 2GHz (for Australia: Intel Pentium 4 2.2 GHz, Pentium M 1.5 GHz or equivalent AMD Athlon 64)
Tuner
* Digital terrestrial TV standard: DVB-T (MPEG-2, MPEG-4 AVC / H.264)
* Antenna input: MCX, 75 Ohm (MCX to IEC adapter included)
TV Recording Formats
* MPEG-1/2, DivX, MPEG-4 AVC / H.264 (for HDTV recordings only)
Package content:
* USB 2.0 TV tuner stick for DVB-T
* Mini remote control including batteries
* Mini antenna
* Antenna adapter (MCX to IEC)
* USB extender cable
* DVD with Pinnacle TVCenter Pro and video editing softwares, drivers and documentation
* Quick start guide
I would say so yes. It is USB 2.0 and since it supports MCE it features a BDA driver thus making it compatible with TransEdit.
I bought the nanostick and it works excellent with Transedit. Transedit now shows average bitrate for scrambled ann fta services.
I hope that a view of max/min bitrates can be added in future versions of TransEdit.
For satellite is much easier as all measurements can be accessed online from the excellent site at http://www.linowsat.de
Edited by Bobben
