osd channel switch
biffo
How to keep osd active when I switch channel by osd? I remember that my osd used to stay active, but now it went off every time I change channel.
thanks
You have to set "Overlay" as renderer in "Settings /Options / DirectX"...
:lol:
:lol:
no, I try to explain better . I'm already able to see the osd favourite channel list . But when I select a channel and then press enter , the channel appears but the osd went off. If I want to change channel again I have to re-enter the osd. I just want the osd to stay on.
thanks
Ah, now I got it!
To do it you have to add a line in the "setup.xml" file you find in your "Configuration folder" (you'll be directed in it clicking on "About / Configuration folder").
With DVBViewer closed, add in the "OSD" section of "setup.xls" the following line:
<entry name="closechannellist">0</entry>
You find described this and other tweak in the "Tweaks.txt" file located in the main program folder (normally "C:\Program files\DVBViewer")...
:lol:
